TimageTK - Geometry
TimageTK - Geometry (Tissue Image ToolKit) is a Python package injecting tools from the computational geometry field into the analysis of images of multicellular tissues, both in 3D and 2D.
Overview
The package provides tools structured around 4 main functionalities
Image Surface
Create triangular meshes representing the surface of tissues (from raw or segmented images) or the interfaces between adjacent cells (walls)
packages/image_surface.html
Tissue Complex
Topological representations of tissues as cellular complexes: simplicial complexes of cell adjacency and (triangulated) polyhedral complexes of cell geometry
packages/tissue_complex.html
Features
Compute geometrical features on cells and walls using mesh representations (normals, curvatures) and process features using advanced operators
Signal Quantification
Combine intensity images and mesh representations of the tissue to quantify signals in elaborate ways (normal sampling, wall signal polarities)
Getting started
Installation
TimageTK - Geometry is made available as a Conda package, and can be easily installed using the following commands:
conda config --add channels conda-forge
conda config --add channels mosaic
conda config --add channels morpheme
conda install timagetk_geometry
For a more advanced usage, have a look at the Installation Guidelines
Examples
In the Examples section, you will find various working examples detailing the basic usage of the library.
